2014 TC Check engine light throwing a P0442 and P0455 code
Postby withalligators » Mon Feb 26, 2018 10:48 pm
Hey Folks,
My 2014 Transit Connect has a check engine light throwing the aforementioned codes indicating a small and large EVAP leak. What components should I look at changing?
I can see the purge valve right between the air box and intake
I can see the EGR valve right to the driver's side of the engine
And that's all I can find. I'm not sure where the vent canister/vapor canister is hidden, or even what else I should be looking for. I'm fairly new to these systems, coming from a 94 cummins diesel.
Please help!
Cheers
withalligators
Re: 2014 TC Check engine light throwing a P0442 and P0455 co
Postby withalligators » Thu Mar 01, 2018 1:02 am
Bump, anyone?
withalligators
Postby liteace » Sat Mar 03, 2018 10:56 pm
Just follow the inlet side of the purge valve and you should find the canister, sometimes they're hidden under the fender, could be a leak, could be the sensor
liteace
