2011 TDCI ENGINE UPGRADE
Postby ozzyboy » Wed Feb 28, 2018 7:22 pm
Is it possible to put a more powerful diesel engine in a 2011 tdci 90 bhp
mine is knackered as belt has broken so thinking maybe focus/mondeo 1.8 tdci 115 or so
ozzyboy
Re: 2011 TDCI ENGINE UPGRADE
Postby paul2012 » Fri Mar 02, 2018 9:46 pm
KKDA engine from a focus or Mondeo mk4 QYBA engine are a direct replacement. Although is will only run a 90ps. :idea:
You can run it at 110ps by fitting correct injectors, VNT turbo, MAF with associated wiring. Then have PCM reprogrammed with 110ps calibration for Connects. I have done this on my Last Connect project 8)
PS You'll also require forward section of exhaust (Oxidation cat) to suit. As 110ps are different to 90ps.
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby ozzyboy » Fri Mar 02, 2018 10:45 pm
thanks for that
might have the chance of a 2.2tdci mondeo complete car
have you seen this conversion done
cant find much online
ozzyboy
Postby karl » Fri Mar 02, 2018 10:51 pm
ozzyboy wrote:thanks for that
paul is the man for this a think he done the 130 ps conversion in a transit but ended up doing something else :D
karl
Tranny Lover!!!
Postby ozzyboy » Fri Mar 02, 2018 11:07 pm
it dosent seem a popular conversion
ozzyboy
Postby karl » Fri Mar 02, 2018 11:10 pm
ozzyboy wrote:it dosent seem a popular conversion
bit of advice mate
make sure it runs and has no fault codes for injectors or pump :wink:
karl
Tranny Lover!!!
Postby ozzyboy » Fri Mar 02, 2018 11:30 pm
yeah your right
ive had problems with the pump breakdowns before
ozzyboy
Postby karl » Fri Mar 02, 2018 11:51 pm
ozzyboy wrote:yeah your right
me dads 130 ps Mondeo is at 206,000 plus and we think its the same pump and injectors :shock:
we change the oil and filter every 6 months.and fuel filter is every 2 years :shock: :shock:
and the power out of it is unbelivable :lol:#
# forgot to say me dads is a 2003
karl
Tranny Lover!!!
Postby ozzyboy » Fri Mar 02, 2018 11:54 pm
bought a few bits off a taxi guy had an st on 220000 all original parts however his mate did something wrong when changing the first clutch and it was never right after that so he broke it
ozzyboy
Postby ozzyboy » Sat Mar 03, 2018 12:28 am
forgot to say
the donor car is a 2006 2.2tdci
can i keep the 6 speed box
ozzyboy
Postby karl » Sat Mar 03, 2018 12:33 am
ozzyboy wrote:forgot to say
if you change everthing over from donner car, it will run but for the 6 speed box you better ask paul :D
karl
Tranny Lover!!!
Postby paul2012 » Sat Mar 10, 2018 12:09 am
6 Speed gearbox wont fit Connects. I've already tried it. 8)
paul2012
Postby ozzyboy » Sun Mar 11, 2018 9:03 pm
thanks for that Paul
ozzyboy
