karl wrote:will tdci clocks work on a tddi connect
Brains_transit wrote:karl wrote:will tdci clocks work on a tddi connect
Wouldn't think so as it's on a different dash loom but course they work if Paul has done the work
paul2012 wrote:Yes Connect TDCI instrument cluster will work on a TDDI. - BUT only early 2000-2006 Clusters.
One from 2006-2009 Connect won't work in a 2000-2006 connect & vice versa due to communication protocols between cluster & PCM.
(SCP on early Connects & HS-CAN from 2006 onwards)
karl wrote:paul2012 wrote:Yes Connect TDCI instrument cluster will work on a TDDI. - BUT only early 2000-2006 Clusters.
the ones i have is a 2008
paul2012 wrote:karl wrote:paul2012 wrote:Yes Connect TDCI instrument cluster will work on a TDDI. - BUT only early 2000-2006 Clusters.
Cluster from a 2008 model will not work in a 2000-2006 Connect TDDI
