wiper motor and washer jet fault
Postby cookermanmike » Mon Mar 05, 2018 9:30 pm
I would like help locating a wiper motor and washer jet fault on my ford transit connect. Reg YC62 SMV. Suddenly during the snow last week I went to turn off the wipers and they kept going? then they turned off, I had tried to use the washers but at -4 degree they wouldn't work duh! I turned the wipers on again and this time they would not turn off again. The problem remains . I removed the wiper relay and this stopped the slow speed so now my wipers only work on full speed. I have checked all the fuses ( 20amp yellow) and they are fine. Three days on and the problems is the same, the washer motor does not go - no buzz and the wipers with the relay in run continually at one speed no matter the setting unless its fast then they are fast! Please help, been a great van for two plaus years now on 72k miles and been service since i have had it on regular intervals. Many thanks Mike
cookermanmike
Re: wiper motor and washer jet fault
Postby Kenton » Sun Mar 11, 2018 2:21 pm
Possible stalk problem there too maybe? :?:
2005 T230 LX 90 TDCi LWB
ST 17" alloys
Focus ST170 seats
Fiesta Zetec S/W & G/K
Sport spoiler
Blacked h/lights
Side bars
Facelift rear lights
Lined/carpeted
Lowered on Gaz kit
110 intercooler
De-Cat
Remapped
Kenton
Postby cookermanmike » Tue Mar 20, 2018 2:22 pm
HI
Turns out the wiper motor was at fault, garage took the motor out and found supply from park was continuous and this kept the motor going, they also found that continual attempts to run the wash pump had blown a fuse and this was replaced. Seems ok now, hope this helps
cookermanmike
Postby Kenton » Tue Mar 20, 2018 8:39 pm
But if the feed is still live in park, and the motor had been removed, how is this the fault of the motor?? Also you said you checked all the fuses. Sounds a very contradictive diagnosis to me. Bet all this wasn't cheap either.
ST 17" alloys
Focus ST170 seats
Sport spoiler
Blacked h/lights
Side bars
Lined/carpeted
Lowered on Gaz kit
110 intercooler
De-Cat
Remapped
Kenton
