Dan sheraton wrote:Hello just wondering if anyone can help me??
I have 2010 transit Connect and have problems with my central locking!
Sometimes my side door and back door will unlock then other times it won’t unlock at all!
There’s power going to the doors as I can hear it trying to unlock when I use the fob but it seems like it doesn’t have the power the actually move the latch!
I’ve changed the battery on the van and battery in the key fob but still no joy
Just wondering if anyone’s had the same
Problem or whether it’s the locking mechanism that needs replacing???
Cheers
Might just be the door position itself which needs adjusting, if the latch is under load when trying to unlock, they will often struggle, as the rollers and latches wear a bit, the door will tend to drop slightly, might only be a mm or so but that's all it takes.
If I park my van on a slope or unlevel ground, the van chassis will twist slightly and cause the lock mechanism to load up a bit, pushing on the door adjacent to the lock mechanism whilst using the fob sometimes helps.
