Engine searching
Engine searching
Postby Rob Heath » Wed Mar 07, 2018 6:15 pm
I've just brought a really tidy 56 plate connect for an absolute steal, the only problem being is that the engine 'searches', the revs sit nicely at around 800ish rpm but every few seconds it climbs probably 500rpm and then drops again.
I haven't driven it yet as it's not insured so not sure how it pulls on the road, there's no smoke and starts up easily.
I've put a new battery on today and all the stuff to do a service....fuel filter, oil filter etc etc.
Before I have a good poke around are there any obvious/common things on the connects that may cause this?
TIA
Rob Heath
Re: Engine searching
Postby karl » Fri Mar 09, 2018 5:14 pm
could be the fuel pressure regulator
siemans system
karl
Tranny Lover!!!
Postby Rob Heath » Fri Mar 30, 2018 5:03 pm
Turns out the injectors had been 'messed' about with and the wiring order was wrong for the injectors, runs very sweet now.
Rob Heath
