Transit connect brake pipes
Postby 015 karlos » Mon Mar 12, 2018 1:11 pm
Hi all, we have a transit connect in, minus its brake pipes, and was asked to make up and fit new ones for the mot. Customer took off the pipes and binned them, so can't replace them like for like.
My problem is....the load sensor, looking at it from above, there are four holes for the brake pipe unions, two on the left are larger bores than the two on the right. Would I be right in thinking that the two larger bores on the left are the inputs from the front of the car, and the right hand smaller bores feed the rear brake drums ? #confussed.com
015 karlos
