Problem fitting Mk3 Mondeo inner door handles...
Postby Rossco701 » Mon Mar 12, 2018 6:07 pm
Sorry to keep pestering you all. I have been told that Mk3 chrome inner door handles fit with slight modification. I have removed my standard door handles and they look nothing alike... not even close. Has anyone else fitted these handles before and if so can you please offer advice. Many thanks
Rossco701
Re: Problem fitting Mk3 Mondeo inner door handles...
Postby doebag » Mon Mar 12, 2018 9:21 pm
I think the only bit that matches is the lever itself, you have to remove it and fit to the Tourneo housing/mechanism.
doebag
Postby Graham Taylor » Tue Mar 27, 2018 10:01 am
You need to just swap the levers. Easy to do just cut one end of the pin that joins the levers, refit and push the pin back in. You can put a screw or similar to stop the pin dropping if you want but mines never moved.
Graham Taylor
Postby Rossco701 » Tue Mar 27, 2018 9:08 pm
Thank you Graham I appreciate you posting up a solution. I cut off the bottom of the pin and taped a screw in the bottom. The look mint. Once again thank you
Rossco701
