Coolant change
Coolant change
Postby Sparky322 » Wed Mar 14, 2018 9:05 am
Hi I’m new to here What is best way of getting air out the system puts new waterpump on but now not getting any heat through vents so it must be a airlock any suggestions
Sparky322
Re: Coolant change
Postby Chug » Wed Mar 14, 2018 10:27 am
Heater set to hot, leave the cap off the coolant resevior, run the engine at a fast idle, squeeze all the coolant hoses you can to push any air out.
Chug
Re: Coolant change
Postby ned » Wed Mar 14, 2018 3:31 pm
I've just changed the coolant in my van, I filled the expansion tank with my coolant/antifreeze mix left the cap off and let the van idle for 10 minutes with the heater on full. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
