2011 connect 1.8tdci vibration
Postby Scottyboy75 » Wed Mar 14, 2018 10:05 pm
I’m getting a vibration on idle which gets worse peaking at about 2500rpm, doesn’t change with clutch? Any ideas? Sounds like the engine is on the dashboard
Scottyboy75
Re: 2011 connect 1.8tdci vibration
Postby Svb1780 » Mon Mar 19, 2018 2:16 pm
mine is similar did you get a fix in the end?
Mine is between 1800 -2000 rpm when accelerating, I am worried its going to cause damge.
Good Luck
Svb1780
Postby Scottyboy75 » Mon Mar 19, 2018 2:27 pm
Going in tomorrow, glow plug fault is causing dpf to clog. Fingers crossed that’s the prob although he did mention possible flywheel issue.
Scottyboy75
Postby Svb1780 » Mon Mar 19, 2018 3:49 pm
Fingers crossed then pal can you let me know the outcome its been a killer month tyres clutch and service..... Any help welcome. REGARDS & Thanks
Svb1780
Postby Kenton » Mon Mar 19, 2018 4:32 pm
Mine has been doing the same since I've had it (4 years) only wobbles when stationary, in neutral, and increasing throttle slowly. At around 1500 and 2k revs it's starts the wobble, and when cold it produces blue smoke too. I have always thought it's misfiring... All glow plugs have been replaced - which were not working, and still the same problem. Does not use any oil, so seals and anything related to burning engine oil must be false... Gonna book it in with a diesel specialist and get a diagnosis. It has been suffering very rough running when cold since i have had it too. Smokes loads on start up and does not tick over smooth at all. Does start on the button every time though!..... ? Good luck pal, and let us know.
Connect 05 T230 LX 90 LWB
ST 17" alloys & Toyo Proxes
Focus ST170 seats
Fiesta Zetec steering wheel & G/K
Mondeo Door handles & vents
C/F Bonnet wrap
Side bars
Facelift rear lights
Fully lined & carpeted
K&N Panel filter
Lowered
Kenton
Postby Scottyboy75 » Tue Apr 03, 2018 8:11 am
Ok no smoking or nothing, went in for eml light and was the fuel vapor valve, slight improvement on vibration but going back in this week for a proper look as they were very busy, will keep you posted
Scottyboy75
