Battery drain in cold weather
Postby G.M » Sun Mar 18, 2018 8:48 pm
Whenever the weather turns cold the battery on my 2012 connect drains right down over night to the point not even the central locking works in the morning.
I've bought a new battery and exactly the same happens with that one....In cold spells like this weekend i have to disconnect the negative terminal to guarantee a charged battery in the morning.
Any ideas why or how this happens please guys.
G.M
Re: Battery drain in cold weather
Postby mrtn » Mon Mar 19, 2018 10:47 am
You need to measure the drainage with an ampermeter. A battery does not drain itself just because of cold weather. So it's not a battery issue. You might have something turned on in the car.
1.6 Ecoboost A/T LWB '16
mrtn
Postby Altransit » Mon Mar 19, 2018 12:59 pm
........ or you could have a leaky alternator diode :idea: Try unplugging the alternator overnight and see if it still drains.
If it doesn't drain, you'll need to replace the alternator, or fit a new diode pack.
If it does, then you'll need to start pulling fuses to isolate which circuit is causing the problem :|
Postby g-man » Mon Mar 19, 2018 4:29 pm
sure i read about a having a usb port can cause flat battery
g-man
Postby G.M » Mon Mar 19, 2018 8:48 pm
The puzzling part is it doesn't drain when the weather is mild. I tested the drain and the reading was 0.7 amp, but that was on a mild evening.
G.M
Postby mrtn » Tue Mar 20, 2018 10:32 pm
Oh damn, 700 mA is a lot.
mrtn
