Fuel gauge working intermittently - Connect 2004 @123000 km
Postby Shitblast » Tue Mar 20, 2018 1:06 am
There are creaky sounds coming from the dashboard, with the ignition on, before turning the engine. The fuel gage will mostly not rise at all. Sometimes, it rises a little, shakes, and falls back to where it started. Then sometimes, it will rise, but stop randomly, within an interval that matches the volume in the tank. The other gauges seem to work fine.
https://youtu.be/TLlhJJLhl-Y
Some youtube-video suggested heating the panel on an oven. I took it out, and put it on a radiator, at about 85 Celcius, for two hours, and put it back in. No effect. The condensators look fine, and there are no signs of rust anywhere. Not on the contacts either.
This is the model I have:
Shitblast
Re: Fuel gauge working intermittently - Connect 2004 @123000
Postby Shitblast » Fri Mar 23, 2018 6:03 pm
Is it possible to replace the instrument cluster with one from the junkyard? Will I need to reprogram the ECU after that?
Shitblast
Postby Kenton » Fri Mar 23, 2018 7:52 pm
Yeah, just get another from 02 onwards to 09 or 10 (i think) and it's just plug and play, no coding to worry about. Just temporarily replaced mine and it was from a 2002 works fine on all essential dials, but only snags are that the leds have dimmed over the years, the mileometer is reading 308,000 miles! Lol. And the same problem as my original has: the trip reset button and clock set buttons are prone to stop working, which this had, so not only can you not reset the trip, but you can't set the clock either! So male sure the replacement you get is in full working order! Getting my original fully serviced - hence the temporary replacement.
K
2005 T230 LX 90 TDCi LWB
ST 17" alloys
Focus ST170 seats
Fiesta Zetec S/W & G/K
Sport spoiler
Blacked h/lights
Side bars
Facelift rear lights
Lined/carpeted
Lowered on Gaz kit
110 intercooler
De-Cat
Remapped
Kenton
Postby Shitblast » Sat Mar 24, 2018 1:58 am
That's good to know, Kenton. In the meantime, however, I took it apart. Here are pictures from the solderings behind the two contacts. Can you guys see any solderings gone bad?
First contact solderings
Second contact solderings
Shitblast
Postby Shitblast » Sat Mar 24, 2018 2:41 am
..and by the way, Kenton. In another thread, someone said this:
paul2012 wrote:Yes Connect TDCI instrument cluster will work on a TDDI. - BUT only early 2000-2006 Clusters.
One from 2006-2009 Connect won't work in a 2000-2006 connect & vice versa due to communication protocols between cluster & PCM.
(SCP on early Connects & HS-CAN from 2006 onwards) :wink:
Proposition:
What would you guys think if I put a heat-gun to the solderings, to re-flow them. Would I risk overheating anything else?
Shitblast
Postby Shitblast » Sat Mar 24, 2018 4:02 pm
So, I put everything back together, without heat-gunning anything yet, as I needed to go for a drive. Now, the tacho and speedo won't work either. I suspect it may have something with to do with the tacho- and speedo-indicator arms taking the stepper motor rod with them when I lifted them from the cluster assembly front. Will the stepper motor work after reinserting the motor arm?
Shitblast
Postby Shitblast » Sun Mar 25, 2018 12:49 am
I also did the dash cluster self-report-and-calibrate procedure a couple of days ago- inserting the key, pressing the right pushrod, and turning on the ignition. All the arms arced across fine, except for the fuel gauge, which made rickety movements and sounds, and did not return to its starting point.
Shitblast
Postby karl » Sun Mar 25, 2018 1:06 am
i have a set off clocks if you need them
fully working and showing 125,000 miles
Can post anywhere in the world
£50 plus postage :D
sorry my clocks wont work on a tddi connect :( :shock: different wiring loom etc
karl
Tranny Lover!!!
Postby Shitblast » Mon Mar 26, 2018 4:12 pm
Ok, Karl :-). In the meantime, I ordered a used one from the yard. I've also managed to get the speedo and tacho to work again. It turned out that I had to pull the stepper motor arm somewhat back after inserting it. It didn't help just inserting it.
Shitblast
Postby Shitblast » Thu Apr 05, 2018 9:45 pm
Crap, the used one from the yard doesn't show the right mileage for the car. Works fine otherwise. Is the mileage not stored in the ECU, but in the instrument cluster?
Shitblast
