Injector Coding Confusing Instruction.
Postby axxeman » Wed Mar 21, 2018 8:07 pm
Hi all - whilst waiting for my replacement injectors to arrive, I started reading up on the coding how-to guides and came across this;
"Before programming/coding injectors it is necessary to wean the vehicle at least 8 hours."
What on earth does that mean? It came from here; https://www.diagnoses.biz/data/mediablo ... nfo-en.pdf
axxeman
Re: Injector Coding Confusing Instruction.
Postby ned » Wed Mar 21, 2018 8:14 pm
Wtf :?: when I put new injectors in my mk6 I just fitted the injectors and programmed them straight away then went for a drive, make sure you program them correctly, how do you wean an engine?. N
03 transit 125t280 2.0 tdci swb executive college blue 92 crewcab. Built in Belgium so deserves lots of love. 212,000 miles on the clock.
Instructions for use. fill with fuel. start engine. drive like a t#@t.
ned
Postby Graham Taylor » Tue Mar 27, 2018 9:53 am
I'm assuming they are Delphi? just fit and code them. Take it for a run to check they are ok, if not running right then code them again as sometimes it can take a couple of goes.
Graham Taylor
Postby axxeman » Wed Mar 28, 2018 12:35 am
Graham Taylor wrote:I'm assuming they are Delphi? just fit and code them. Take it for a run to check they are ok, if not running right then code them again as sometimes it can take a couple of goes.
Yeah they are - and I have heard about the multiple coding issues. Thanks.
axxeman
Users browsing this forum: daz5885, Google Adsense [Bot]
