Injector Coding Confusing Instruction.
Postby axxeman » Wed Mar 21, 2018 8:07 pm
Hi all - whilst waiting for my replacement injectors to arrive, I started reading up on the coding how-to guides and came across this;
"Before programming/coding injectors it is necessary to wean the vehicle at least 8 hours."
What on earth does that mean? It came from here; https://www.diagnoses.biz/data/mediablo ... nfo-en.pdf
axxeman
Re: Injector Coding Confusing Instruction.
Postby ned » Wed Mar 21, 2018 8:14 pm
Wtf :?: when I put new injectors in my mk6 I just fitted the injectors and programmed them straight away then went for a drive, make sure you program them correctly, how do you wean an engine?. N
viewtopic.php?f=27&t=209987
viewtopic.php?f=27&t=168296
ned
Postby Graham Taylor » Tue Mar 27, 2018 9:53 am
I'm assuming they are Delphi? just fit and code them. Take it for a run to check they are ok, if not running right then code them again as sometimes it can take a couple of goes.
Graham Taylor
Postby axxeman » Wed Mar 28, 2018 12:35 am
Graham Taylor wrote:I'm assuming they are Delphi? just fit and code them. Take it for a run to check they are ok, if not running right then code them again as sometimes it can take a couple of goes.
Yeah they are - and I have heard about the multiple coding issues. Thanks.
axxeman
