09 connect rear caliper carrier bolts
Postby pestguard1 » Tue Mar 27, 2018 6:37 pm
Can anyone tell me the size of the bolts that hold the rear caliper in place ..(not the hex bolts ) the 2 that hold the carrier to the hub
pestguard1
Re: 09 connect rear caliper carrier bolts
Postby paul2012 » Tue Mar 27, 2018 7:22 pm
pestguard1 wrote:Can anyone tell me the size of the bolts that hold the rear caliper in place ..(not the hex bolts ) the 2 that hold the carrier to the hub
There's 2 slide pins that holds rear caliper to carrier. Ford Part no F6087586
The 2 bolts that holds carrier to hub are Hex bolts. (M12 x 1.72mm)- Ford Part no F1447853
Project 2003 Transit mk6 T280 - mk7 2.2 TDCI engine conversion
2015 Vauxhall Astra Tech Line GT 2.0 CDTI 165ps
Ford IDS PCM updates Fuel pump/Key coding services
SUBCRIBE to my YouTube channel https://www.youtube.com/channel/UCoEIqO ... 3qiAsAq_8w
paul2012
