VCM II Module Programming
Postby dannysconnect » Wed Apr 04, 2018 1:22 pm
Hi All,
Recently installed VCM II V86 onto my laptop
Used it to try and remove the speed limiter off a customers 2015 Transit Connect
I get this message
Module programming: - Selection unavailable
Can anybody help?
Dan
Car Van servicing, diagnostics & Electrical
Cover Berks and Bucks and West London area
dannysconnect
Re: VCM II Module Programming
Postby karl » Wed Apr 04, 2018 6:37 pm
you will need newer version to remove it
or you dont have the moduale programming file
karl
Tranny Lover!!!
Postby paul2012 » Fri Apr 06, 2018 12:03 am
karl wrote:you will need newer version to remove it
Yes newer version of IDS is required
V86 covers models up to 2013 & is too old for 2015 Connects. - Lastest is V109.01
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby karl » Fri Apr 06, 2018 9:33 pm
yes v109.01 is the latest out 8)
karl
Tranny Lover!!!
Postby dannysconnect » Sat Apr 07, 2018 6:36 pm
thanks
dannysconnect
Postby Bowtay » Wed Apr 11, 2018 8:38 pm
Can I jump on this thread I tried removing a speed limiter on a 2016 connect today the ids says it cannot carry on as the airbag module has a different vin number to the rest of the other modules on the car I also tried viewing configuration it uploaded but all the boxes said not in use
Sent from my SM-G930F using Tapatalk
Bowtay
Postby Bowtay » Fri Apr 13, 2018 6:27 pm
Update my ids won't remove the speed limiter off a 2016 connect we took the van to ford they removed it no problem does anyone know if the clone ids can remove a 2016 connect speed limiter I have a good quality clone
Bowtay
