P0251 P0250
P0251 P0250
Postby Moles » Thu Apr 05, 2018 5:13 pm
Hello. Could do with some help...... hope your sitting down. My 53plate connect stopped working with a bang about six weeks ago. Called the AA they came out and couldn’t fix it. Was given the code P0251 by the AA man, got Toad to loacal garage. They told me the pump had gone. Having just spent money on new starter and having it sign written I told them to fix it. I’m now at the stage where I’ve a new fuel pump new injectors fitted and it won’t run. It’ll start for a short while then cut out. And the code showing at garage is now P0250. But they seem not to know what’s wrong. All they’ve told me is they’ve had it before?? Anyone on here any ideas, I’m further in the hole with this van and can’t teally write off what I’ve spent trying to get it run. Thanks Mike.
Moles
Re: P0251 P0250
Postby Altransit » Thu Apr 05, 2018 5:17 pm
Do you know if it's a TDDi or a TDCi :?:
Re: P0251 P0250
Postby Moles » Thu Apr 05, 2018 5:30 pm
TDCI
Moles
Re: P0251 P0250
Postby paul2012 » Thu Apr 05, 2018 5:33 pm
P0251 Injection Pump Fuel Metering Control "A"
Common issue for 2003-2006 Connect 1.8 TDCI engines. - New metering solenoid should be fitted.
P0250 Turbocharger/Supercharger Wastegate Solenoid "B" High
Early 2000-2006 Connects don't have VNT turbo's with elec actuators :!:
Garage is ripping you off. - Get a second opinion
Project 2003 Transit mk6 T280 - mk7 2.2 TDCI engine conversion
2015 Vauxhall Astra Tech Line GT 2.0 CDTI 165ps
Ford IDS PCM updates Fuel pump/Key coding services
SUBCRIBE to my YouTube channel https://www.youtube.com/channel/UCoEIqO ... 3qiAsAq_8w
paul2012
Re: P0251 P0250
Postby Moles » Thu Apr 05, 2018 6:15 pm
Any one know the part number for that? I’d like to be armed with as much info as I can be when I take the van back and get it towed else where. Also what’s rough price for one? Been ripped off enough. Thanks.
Moles
Re: P0251 P0250
Postby karl » Thu Apr 05, 2018 6:30 pm
AS paul said get a second opinion, and to be honest paul knows these like the back of his hand :D
were are you in this world :D
karl
Tranny Lover!!!
Re: P0251 P0250
Postby Moles » Thu Apr 05, 2018 6:36 pm
Oh I’ll be getting second opinion tomorrow. Just wanted to be armed with info.
Moles
Re: P0251 P0250
Postby paul2012 » Fri Apr 06, 2018 12:00 am
Delphi Fuel metering solenoid for 2003-2006 Connect 1.8 TDCI
Ford Part No F1329098 (4S4Q-9G586-AA )
Should be able to get one fairly cheaply from Ebay :wink:
paul2012
