Oil Filter removal on Transit Connect 2010 Model
Postby dave750 » Sat Apr 14, 2018 9:32 pm
Hi Guys, thought I would buy some good quality oil and oil filter to give the good old van a bit of TLC. The oil filter is a right bitch to get to. I have removed the drivers wheel and the small plastic pulley cover but it is so tight to get to. Struggling to get the oil filter loose what removal tools do you guys use please. Any advice would be appreciated
dave750
Re: Oil Filter removal on Transit Connect 2010 Model
Postby mk2dk » Sat Apr 14, 2018 10:11 pm
Hi dave750
I use a Facom Ratchet oil filter removal tool, it does the job each time. Access is better from below, if you jack up the front of the van.
mk2dk
mk2dk
Postby doebag » Sun Apr 15, 2018 9:21 am
From underneath as well, either pit or jacked up.It comes out between the engine and [I think] the steering rack
As long as it has not been put on with a tool, I always find a wearing a rubber glove gives plenty of grip to remove the filter.
doebag
Postby blue estate » Sun Apr 15, 2018 12:51 pm
3rd for underneath , I’ve owned countless Focus with same engine and from below is only way
72plt MG 5 ev estate Battery car
blue estate
Postby Altransit » Sun Apr 15, 2018 2:38 pm
The new 1.6 is soooo much easier to get at, and I believe that the 1.5 is the same :)
Postby dave750 » Mon Apr 16, 2018 11:51 pm
Many thanks to all your replies, I will be purchasing some car ramps then to tackle the job from underneath, great responses gives me the confidence to carryout the job.
dave750
