Oil filter location question
Postby cavalino » Fri May 18, 2018 2:49 pm
I want to change the oil between services in my 66 plate transit connect 1.5tdci,and would like to know where the oil filter is located. I understand its a bit difficult to get to. Does any one know.thanks
cavalino
Re: Oil filter location question
Postby Piglet » Mon May 21, 2018 11:00 am
On the 1.8 it's up the back of the block above the O/S drive shaft.
Don't know about the 1.5
Piglet
Postby Altransit » Mon May 21, 2018 6:53 pm
I think it's the same as the 1.6, and on that engine it's fitted on the engine block, passenger side front, above the gearbox. I'm not sure of the ancilliary layout on the Connect, but on the Focus, it's easy to get at when you remove the air filter housing :idea:
