Can blanking plate cause P0490?
Postby Piglet » Thu May 31, 2018 3:57 pm
Vans has started 'hunting' while cruising along.
Bought a scanner & installed Forscan and have got P0490 'high EGR voltage'
So, given that the van has had a EGR delete and has had a plate fitted, though removed at the moment,
why am I even getting EGR faults codes??
Do I need to strip & clean the EGR?
Piglet
Re: Can blanking plate cause P0490?
Postby karl » Fri Jun 01, 2018 6:43 pm
egr hasn't been deleted if you getting egr codes :shock:
karl
Tranny Lover!!!
Users browsing this forum: doebag, Google Adsense [Bot]
