Water Leak
Water Leak
Postby John235 » Fri Jun 15, 2018 10:48 am
Hi, guys. I have a bad leak on my 08 plate TDCI. It is coming from a metal pipe about 12mm diameter, that is at the back of the engine, hidden in amongst the manifold plumbing.
Does anybody know the easiest way to get at this pipe to replace it?
It would also help to know what this pipe is for, so I can identify it to get a replacement
John235
Re: Water Leak
Postby Piglet » Fri Jun 15, 2018 10:39 pm
which one, there are a few.
Piglet
Re: Water Leak
Postby John235 » Sat Jun 16, 2018 10:21 am
Don't actually know which pipe. I only saw it while it was up on a ramp at the garage. Problem is, the van is in Worcester, I am in Cumbria!
Does anybody have any pics of the rear of the engine?
John235
Re: Water Leak
Postby John235 » Wed Jun 20, 2018 11:37 am
Problem solved. There is a metal pipe, runs around the engine, diappears underneath/behind the manifold are. Only a pin-hole showing, but the water was pouring out!
Pipe now replaced and everything appears to be back to normal. At least, it got me home last night, and did not overheat or use any water!
John235
Re: Water Leak
Postby Piglet » Wed Jun 20, 2018 1:39 pm
Think I know the one, gets right in the way when dropping the gearbox for the clutch.
Doesn't sound like the coolant has been changed as often as it could have been though.
Well done for sorting it.
Piglet
