Egr valve ford transit connect 56 plate
Postby Stefan77 » Sun Jun 17, 2018 1:40 pm
Hello
Anyone know how to remove the egr valve on connect 56 plate 1.8 tdci
Cheers
Stefan77
Re: Egr valve ford transit connect 56 plate
Postby liteace » Wed Jun 20, 2018 10:39 pm
You cant remove it, its part of the intake manifold, the only thing you can do is blank it
liteace
Postby paul2012 » Thu Jun 21, 2018 5:55 pm
Under new MOT rules (20th May 2018) EGR valves are now inspected for MOT.
EGR valves that have been blanked off or removed (emission systems tampering) will be a MAJOR defect. Engine MIL/EML is also a MOT MAJOR defect.
MAJOR defect results in automatic MOT refusal. :!:
Further more diesel smoke test has also changed. Fast pass has been abolished. Diesel emissions are now checked against MANUFACTURERS LIMITS - Know as plate value.
ALL Connects have manufactures limit listed on vehicles VIN label. :!:
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
Postby Kenton » Thu Jun 21, 2018 9:06 pm
Holy wow!.... Just out of interest, how do they check the EGR valve paul, without removing? For which, like mine, is not removable without removing the inlet manifold??
2005 T230 LX 90 TDCi LWB
ST 17" alloys
Focus ST170 seats
Fiesta Zetec S/W & G/K
Sport spoiler
Blacked h/lights
Side bars
Facelift rear lights
Lined/carpeted
Lowered on Gaz kit
110 intercooler
De-Cat
Remapped
Kenton
Postby liteace » Thu Jun 21, 2018 11:39 pm
They will give it a visual check, they wont / cant dismantle it, they're not allowed, if they see a shiny blanking plate thats just been fitted they might question it, but it could be a new gasket !!
There's a lot of scaremongering out there, read the failure statistics since the new law, its been a month, have you noticed massive drop in traffic on the road due to everything failing its MOT's !!!
liteace
Postby Jasonsmovingco » Wed Jun 27, 2018 2:12 pm
The EGR is permanently set up as part as the entire intake manifold?!?! Who's BRILLIANT idea was that?!?! Talk about planned obsolescence. Geez.It's like Ford doesn't want you making easy repairs. EGR valves are usually not that expensive or hard to replace.
Jasonsmovingco
