Urgent HELP alternator lead
Postby mutley8979 » Sat Jun 30, 2018 11:41 pm
Hi, i've just finished changing my radiator on my 2008 Ford Connect, but I'm left with the lead coming from the alternator and can't for the life of me see where it goes, so the van's not charging Please HELPPPPPP ASAP
Oh it's a 3 wire (red, white and blue ending in a triangular type socket
Someone said it should go to ECU?? where is this, the lead was clipped onto the fan frame so isnt that long...NEED VAN IN THE MORNING FOR WORK!!!!
Martin
mutley8979
Re: Urgent HELP alternator lead
Postby nardi » Sun Jul 01, 2018 12:16 pm
I think that the plug you mention should be plugged into the alternator because there isn't any other way.
nardi
Postby Piglet » Sun Jul 01, 2018 7:15 pm
That sounds like the Smart charge cable, goes from the alternator to a connector clipped by the cooling fan.
Piglet
Postby mutley8979 » Sun Jul 01, 2018 11:37 pm
Hi thanks, i finally found that when i put new rad in the male half of the cable had been pushed between air con rad and front metal work. i'm back on the road now now everything working fine.
thanks for your help
martin
mutley8979
