Hey - thanks
2006 TDCI 1.8 Connect
Previous fob stopped working. Run out of ideas.
Have changed fob batteries. Have bought a new fob and tested a third. Have changed the fuse (behind the fuse box). Have confirmed presence of CL DL RC. Have disconnected aux battery.
The hazard lights double flash when locking with the key.
The central locking cycles when I replace the fuse.
Drivers key unlocks passenger door, and when turned 3 times unlocks the side door.
The rear door handle doesn't work and can't open from outside. They key works.
You can lock all the doors by locking the rear door from inside, but not unlock.
If anyone has any guidance, it'll be most appreciated. Thank you, Rosie x
