Focus mk2 with 1.6 TDCI 115ps (KKDA) engine.
Injectors & VNT turbo are the same used on Connect 1.8 TDCI 110ps.
To upgrade a 2006-2009 Connect 1.8 TDCI 90ps to 110ps
You'll require injectors, VNT turbo with ele actuator, oil cooler, turbo oil feed & return pipes. All from the above Focus mk2.
Connect 110ps foward exhaust section with cat & mounting bracket. Wiring harnes from PCM to electronc actuator on turbo. (Not present on 75 or 90ps connects
You then have to reprogram your Connects original PCM by installing the Connects 110ps calibration onto it.
- PCM (ECU) from Focus will fit connects - (Siemens SID206 PCM) Although its calibration is not compatible for Connects.
To upgrade a 2006-2009 Connect 1.8 TDCI 75ps to 90ps.
Don't need to change any components - Reprogram Connects PCM by installing Connects 90ps calibration onto it.
I have done the above on several Connects with no problems.
