Focus turbo/ecu on Transit Connect 07 1.8 TDCI ?
Postby Phil118 » Sun Aug 05, 2018 11:37 pm
Hi there hoping some1 can help a bit. Ive got a 07 plate transit connect 1.8tdci 90ps and have recently fitted the focus mk1 gearbox and upgaraded to focus mk2 300 brakes. Have read in a few places that the turbo, ecu and injectors from a focus will also fit, with a decent power upgrade, but other forums/sites saying no, can anyone shed some light on this and also if possible, what year/engine etc. Cheers in advance
Phil118
Re: Focus turbo/ecu on Transit Connect 07 1.8 TDCI ?
Postby paul2012 » Mon Aug 06, 2018 4:59 pm
Focus mk2 with 1.6 TDCI 115ps (KKDA) engine.
Injectors & VNT turbo are the same used on Connect 1.8 TDCI 110ps. 8)
To upgrade a 2006-2009 Connect 1.8 TDCI 90ps to 110ps
You'll require injectors, VNT turbo with ele actuator, oil cooler, turbo oil feed & return pipes. All from the above Focus mk2.
Connect 110ps foward exhaust section with cat & mounting bracket. Wiring harnes from PCM to electronc actuator on turbo. (Not present on 75 or 90ps connects :!: )
You then have to reprogram your Connects original PCM by installing the Connects 110ps calibration onto it.
- PCM (ECU) from Focus will fit connects - (Siemens SID206 PCM) Although its calibration is not compatible for Connects.
To upgrade a 2006-2009 Connect 1.8 TDCI 75ps to 90ps.
Don't need to change any components - Reprogram Connects PCM by installing Connects 90ps calibration onto it.
I have done the above on several Connects with no problems. 8)
2009 Jaguar X-Type 2.0D
IDS & GM GDS2 services
paul2012
