There are the ford recommended ones , but i will not tell you them as they are way too high in the mileages
My recommended ones are:
Gearbox - DUE - change oil strait away or every 50,000 ..not sure if it has 2 lots of oil ..hydraulic and gear oil...you'll have to find out about that....tell me exact model of gearbox ..and i'll do some looking> (ford don't recommend a change )
Engine oil and filter - every 6000 or 8000 (change now if you don't know the history) do a double change as you don't know the history ..change it ..run for a week change it again . or put cheap oil in it, run for 20 miles change again.
Brake fluid every 25,000 or 5 years what ever comes first. ( DUE, change now if it looks dark)
Diesel filter every 25,000 - DUE - (change now if you don't know the history)
Cambelt - 80,000 .(or change at 6 years)
Air filters inc cabin filter ..take them out and inspect, if they look dirty change them. - then inspect every 5000
Power steering fluid - do a change at 100,000..or sooner if you plan on keeping it for a long time.(ford don't recommend a change )
Radiator flush and new antifreeze .DUE .do it as soon as possible.
Service the EGR valve , dissemble and clean the boost pipes intercooler , probably due.
Brakes will need inspecting, may need replacing.
top up Adblue
Washer bottle
otherOil hinges
Clean battery terminals
Check rubber exhaust hangers are intact
Check tyres
Think that's enough for you to be doing for now
