30,000 Mile Service on a 110 230 tdci
Postby ME » Fri Apr 04, 2008 11:58 am
£340 :shock:
Its a Major service apparently :roll:
Anyone know what they Do for This One
Mercedes Vimto Premium
ME
Re: 30,000 Mile Service on a 110 230 tdci
Postby BigNeil » Fri Apr 04, 2008 1:15 pm
30,000-MILE SERVICE
Ford Recommended Services:
Change engine oil and replace oil filter
Change automatic transmission/ transaxle fluid on all vehicles equipped with AX4S, 4R100, 4F27E transmission/transaxle. Inspect automatic transmission fluid level on all other vehicles, if equipped with dipstick. Consult your dealer for your particular requirements
Replace engine air filter (not required PZEV Focus)
Replace fuel filter (except Natural Gas)
Replace cabin air filter, if equipped
Replace climate-controlled seat filters (Freestar, Monterey and LS, if equipped)
Inspect tires for wear and rotate
Inspect brake pads/shoes/rotors/drums, brake lines & hoses, and parking brake system
Inspect wheel ends for endplay and noise
Inspect engine cooling system and hoses
Inspect exhaust system and heat shields
Inspect steering linkage, suspension and, if equipped, driveshaft and ball joints
Inspect fuel tank (Natural Gas)
Perform Multi-Point Inspection (Recommended)
Additional Dealer Recommended Services:
Perform transmission service (all vehicles equipped with AX45, 4F50N, 4R100 and 4F27E)
Change orange coolant at 150,000 miles
Wheel alignment and electronic wheel balance (2WD or 4WD wheel as required)
Clean and lube caliper slides
BigNeil
Postby ME » Fri Apr 04, 2008 3:43 pm
So as mine is Manual and No Aircon and just had Tyres fitted i think thats a Bit Steep for a Oil change + 3 Filters
ME
Postby BigNeil » Fri Apr 04, 2008 3:46 pm
why do you not ask them what they are going to do ?
ask them how much the oil is going to cost and can you bring your own ?
and ask them how much labour they are charging ?
and remember you can take it to any gargae to do the service as long as they stamp the book !
:D
BigNeil
Postby martynx » Sat Apr 12, 2008 9:43 pm
:D
And use ford parts :wink:
martynx
Postby martynx » Sat Apr 12, 2008 9:59 pm
Whats the going labour rate ? £79plus vat per hour ???????????? - - Just those " inspect " items if done properly have to add up to an hour surely ?? finding a loose hose clip or wrongly routed hose could save loads of future grief, .. but would they do those inspections thoroughly :?: :!:
martynx
