found the wires for rear speakers and power socket with pics
Postby painter4 » Mon Oct 20, 2008 7:07 pm
ok found wires for rear speakers and power socket, you just need to put a 15 fuse in the fuse box behind glove box and buy a socket from ford plugs right in to make power socket (orange and black wires) work easy stuff ,the speakers are grey and black .
[img][IMG]http://i530.photobucket.com/albums/dd347/connecttdci/Image009.jpg[/img][/img]
[img][IMG]http://i530.photobucket.com/albums/dd347/connecttdci/Image007.jpg[/img][/img]
[img][IMG]http://i530.photobucket.com/albums/dd347/connecttdci/Image008.jpg[/img][/img]
[img][IMG]http://i530.photobucket.com/albums/dd347/connecttdci/Image010.jpg[/img][/img]
[img][IMG]http://i530.photobucket.com/albums/dd347/connecttdci/Image011.jpg[/img][/img]
painter4
Re: found the wires for rear speakers and power socket with pics
Postby Mike » Mon Oct 20, 2008 7:08 pm
Mike
Wind up merchant!
Postby painter4 » Mon Oct 20, 2008 7:10 pm
thanks mike what did i not do right
painter4
Postby Mike » Mon Oct 20, 2008 8:52 pm
painter4 wrote:thanks mike what did i not do right
Too many [img] tags ;) Take the extra set off each end and the pics will appear.
Mike
Wind up merchant!
Postby Refined Detail » Mon Oct 20, 2008 9:27 pm
Ooh.
Is this the same on all the Connects then? May have to remove my plylining again now to have a look :lol:
Refined Detail
Postby rich31 » Tue Oct 21, 2008 8:45 pm
hi , have you got the part number and/or description of the rear power socket. i went to my local ford commercial dealer, and the parts guy looked as if i had just landed from mars when i asked him. any help??
rich31
Postby painter4 » Tue Oct 21, 2008 9:22 pm
dummies :!: i just asked for power socket no problem came next day 8.50 all in its basically just a cigarette lighter i just cut a 25mm hole in the ply lining and fitted right in easy
painter4
Postby andymdj » Tue Oct 21, 2008 11:01 pm
Hi
The Rear Power socket is FINIS code 4395499 for 5/02-10/04 and appears to be FINIS code 1357349 10/04 on from the details i have been able to find and they are around £10+ vat from info i have received.
Rear speakers from ford are around £40 + vat and should come with the relevant spaker connection if required FINIS 4370985 upto 09/05.
Hope that helps.
andymdj
Postby Refined Detail » Thu Oct 23, 2008 3:08 pm
Still haven't got round to looking for these in mine, but I've already got a 12v socket there which I plylined over temporarily, so presumably have the speaker wires there too 8)
Good news for me too, as I'm just starting to plan stereo changes :lol:
Refined Detail
Postby rich31 » Fri Oct 24, 2008 8:01 pm
ordered my power outlet from local ford dealer in straford on avon, £6.50 +vodka and tonic, bargin should be here monday thanks for help
rich31
Postby painter4 » Sat Oct 25, 2008 10:40 am
just cut off the plugs for the speakers and you can fit anything you want ,i have made some boxes fitted to the ply lining on top of the wheel arches to take a pair of 6x9 mutant speakers that are a great price from a1 motor stores and sound good enough for me :D will change the door speaker at some stage .. i also fitted the power socket to the wheel arch box towards the back door
will take some pics when speakers are fitted should arrive today :D
painter4
Postby Refined Detail » Sun Nov 30, 2008 5:08 pm
Sorry to drag this up.
Ordered a couple of sets of the speaker plug adapters off eBay the other day as had seen this thread, and wanted to to front and rear speakers.
Fronts are semi done (temp woofers from set of 13cm components in there atm lol) yet to decide what to do...
Then removed plylining to look at the rear, and started to get confused as I have the 12v socket already there, but there doesn't appear to be signs of speaker wires. Not just that, my loom runs across the top of the inner skin, whereas in the pics posted on here, yours seem to run along the bottom?
My vans an 04 plate Ex-BT "L" I'm wondering if BT have special spec vans? As it has the orange beacon switch in the front (genuine Ford part it seems) which links to a plug in the rear where the amber light used to be. I also have the 12v socket and 2 rear interior lights.
Anybody else in the same boat?! Any ideas on feeding further wires to the rear if needs be? And finally suggestions for front speakers please!
Sorry for all the questions!
Cheers
Rich
Refined Detail
Postby tottespurs » Mon Dec 01, 2008 12:49 am
is it a lwb or swb
tottespurs
Postby Refined Detail » Mon Dec 01, 2008 9:07 am
SWB...
Refined Detail
Postby tottespurs » Mon Dec 01, 2008 12:16 pm
i think the rear speaker looms were only fitted in the lwb as it is used for thr mpv model
tottespurs
