As soon as you asked which wheelbase I was, it twigged that was probably the case
Ah well.
tottespurs wrote:i think the rear speaker looms were only fitted in the lwb as it is used for thr mpv model
painter4 wrote:tottespurs wrote:i think the rear speaker looms were only fitted in the lwb as it is used for thr mpv model
and maybe only lwb lx as mine is .. i posted the pics
u076216 wrote:Sorry that I dig up this old thread again. I am looking for the counterpart of the following plug. It is the connection cable of the socket in a 2008 LWB. Unfortunately, the images are no longer visible from the beginning of this thread.
After plugging the fuse in the fuse box, I have 12 volts on the plug. I would like to use the plug to charge an emergency lamp in several Connects which have the same unused plug in the back. Then I would not cut off the plug on all vehicles, but could use the original plug and change the lamp from car to car.
Here's the plug on the vehicle from the front and the side. As I said, there are 12 volts on it, so it can not be a speaker cable.
Thanks in advance.
u076216 wrote:This plug will be connected directly to the additonal 12 Volt socket ?
