battery warning light staying on
Re: battery warning light staying on
Postby G MTB » Wed May 27, 2009 11:48 am
This is happening to mine, but it has had new alt and battery replaced 18months ago on warranty. Can anyone post a pic of where I should look to see if wires have corroded please?
http://www.stormstatic.com Shock tactics for your graphics!
G MTB
Postby Altransit » Wed May 27, 2009 12:22 pm
Find the small plug on the back of the alt with the 3 wires on it, and trace the loom back from there. As said, it is in a conduit which you need to strip back so you can visually examine the wires. The fault is usually around 150mm back from the alt plug :wink:
Postby G MTB » Wed May 27, 2009 1:48 pm
Oh aye, I see it. looks like it's already been patched with insulation tape a few times. Going to get my mate to test the battery too later on.
G MTB
Postby G MTB » Tue Jun 09, 2009 12:58 pm
It was the wiring £27 to fix :D
G MTB
Postby Paulham636 » Sat Jun 20, 2009 4:58 pm
Having an issue with the battery light flickering on and off. Have cut back the 3 wire loom for a look but looks in good order but replaced it anyway. Took the van a run but the light did flicker for about ten minutes now it stays off. Was wondering if this is because of the smart charge system is overcharging when
cold ???. Does onybody have a qlue!!!! Please help its driving me nuts.
Paulham636
Postby coconut » Sun Jun 21, 2009 10:24 pm
Some need the 'smart charge fault' DTC cleared before the light will stay out :!:
I miss my 'courtesy van'............140 Glx..now a Jumbo :(
coconut
Ford Technician
Postby VarneElec » Wed Aug 26, 2009 9:36 am
hey guys i have this problem does any one know where i can get a new part from or the part number for it ? ive looked everywere cant get one
thanks in advance
darren
VarneElec
Postby me&myvan » Wed Aug 26, 2009 12:25 pm
viewtopic.php?f=54&t=37471
http://fordtransit.org/forum/viewtopic.php?f=54&t=37471
Read this post, the part number I used is in there somewhere.
Dave
me&myvan
Postby EvilT » Sat Jan 16, 2010 12:41 am
OK- 54 220 1.8 TDCi. I spent Christmas day repairing the loom (blue wire as everyone has said), and checking conductivity etc. Subsequently spent the last couple of days replacing the alternator (serpentine belt on these things is a SOB) and... PRESTO!!! NO difference at all. I still have battery shaped warning light, battery is not charging at all. Suspicion is that it's an ECU fault, had a friend with a Honda which suffered similarly. Anyone else had the experience of replacing the two likeliest suspects with absolutely no result whatsoever? I am supposed to be commuting to London (150 miles) and back for 13 weeks (including last), so this has come at a REALLY bad time. Much as I hate to say it, as I appreciate the driveability and general construction of Fords, this van is looking like a waste of £3,000, and is eating more money as time goes on. Taking bets on whether or not this POS gets me kicked off my degree. :|
Silly driving makes van dead often
EvilT
Postby Altransit » Sat Jan 16, 2010 12:48 am
EvilT wrote: spent the last couple of days replacing the alternator and... PRESTO!!! NO difference at all.
Always a possibility that the new alternator is faulty :?
Postby EvilT » Sat Jan 16, 2010 8:48 pm
True that- what does the belt drive besides the alternator and power steering pump? Went out this morning to find the pulley between the crank and the alternator had sheared off during the night, wondering if I can drive to town for baccy & if it'll make MOT on Wednesday with no belt!
EvilT
Postby EvilT » Sun Feb 07, 2010 4:45 pm
New alternator seemed to work-, got 100 miles out of it, figured all was well, left it at train station for 2 weeks, came back and got it, indicators staying on due to cold- then a further 50 miles and it failed again just as I was pulling into my drive yesterday :shock: . Checked loom (as is perfunctory), still fine. Recharged battery from wall AGAIN. Has to be another wire in the harness or the ECU has gone nuts. Can't be bothered to remove the entire wiring harness and test it- going to Ford on Monday with my "fix it or die" face..
EvilT
Postby jumbotroll » Fri Jul 23, 2010 10:13 am
Great forum.
220 LX Diesel 2006 35500km.
Regards
Jumbotroll
jumbotroll
Postby Altransit » Fri Jul 23, 2010 10:16 am
jumbotroll wrote:Great forum.
We think so :wink: :D :lol:
Nice pics 8)
Postby stee1fm » Thu Nov 25, 2010 11:47 pm
hi all
right then. i.v replaced the 3 wires from the alternator to just under the fuse box. the alternator is just over 12 month old but seem's to be charging ok.
so any idea of where i go next? and where dose the grey wire go when it get's past the fuse box?
thanks stee
stee1fm
