Transit Connect ECU Location
Postby martynx » Fri Feb 20, 2009 8:44 pm
Its time to see if Connect ECU's can be programmed on the bench :idea:
- Is the ECU located in the drivers footwell :?: :
martynx
Re: Transit Connect ECU Location
Postby Turbo Tim » Fri Feb 20, 2009 10:08 pm
drivers side footwell,righthand side
Turbo Tim
Postby martynx » Fri Feb 20, 2009 10:17 pm
Cheers Tim - whats the best way to remove it ? floor mat out or is it on the A post panel ?
martynx
Postby Turbo Tim » Fri Feb 20, 2009 10:33 pm
upside down in floorwell,or you can take out the storage shelf,probably the second thinking about it,
Turbo Tim
Postby martynx » Fri Feb 20, 2009 10:45 pm
Splendid... :)
martynx
Postby coconut » Sat Feb 21, 2009 3:27 pm
Or behind the OSF wing if its the facelifted shape :wink:
I miss my 'courtesy van'............140 Glx..now a Jumbo :(
coconut
Ford Technician
