diagnostic socket
diagnostic socket
Postby unreliable » Mon Sep 07, 2009 4:01 pm
Hi
Sorry to bother you but can anyone tellme where the obd diagnostic socket is on my 2006 connect please
unreliable
Re: diagnostic socket
Postby nokites » Mon Sep 07, 2009 4:37 pm
The D.L.C. is under dash panel, centre of vehicle
OLD CHINESE PROVERB
Man who works for nothing and women who f****s for nothing ---------ALLWAYS GOT PLENTY TO DO
nokites
Postby unreliable » Mon Sep 07, 2009 8:55 pm
Many thanks
unreliable
Postby john54321 » Mon Nov 29, 2010 12:41 pm
Could it be possible that my connect (55 plate) does not have an obd socket? I've checked bloody everywhere, pulled trim panel off under the steering wheel, no sign of the thing. :evil:
Any ideas?
john54321
Postby Kent Discos » Mon Nov 29, 2010 12:50 pm
in the driver footwell, right next to the center console
Jack Wilson | 2011 Transit Mk7 T280 140 Limited |
Kent Discos - http://www.kentdiscos.me.uk
Kent Discos
Postby www.mobilelpg.co.uk » Mon Nov 29, 2010 8:56 pm
Hi,
In the centre console, directly in line with the blower motor switch, go right to the very bottom of that panel and you will feel it sticking out just slightly, if you get your head up in the gap in front of the gear lever, you will just see the connector poking out.
Or if you had an LPG connect you would be spoilt with 2, the second one is behind the panel that houses the headlight switch (there for LPG diagnostics but carries the same OBD info on it)
Edward.
Mobile Automotives and LPG
LPG Servicing and Repairs, Engine Diagnostics, Auto Electrics, Emissions checks.
Tel: 07954 582542 (Mobile)
Tel: 01952 630307 (Landline)
http://www.mobileautomotivesandlpg.co.uk
WE COME TO YOU!
www.mobilelpg.co.uk
