billyjo2002 wrote:Where is the earth/engine strap on a Connect T200 2006 plate?
GND from battery is located near starter motor
andye wrote:first time caller. my 220LX 54 plate connect has had unexplained flat battery syndrome intermittently since new. neither Ford or independent motor electrician can source the fault. it happens if i use the rear doors a dozen times a day or if i leave them open.(but not always). the battery will be dead flat but try to turn the wipers on. jump start is no problem whatsoever. interior lights go out after about half an hour if doors are left open or one minute if closed.
i carry spare battery and jump leads at all times. there is long term damage being caused to the battery as they have to be replaced every year, although the last one with a three year warranty has just lasted for eighteen months before failing to hold a charge. i have about once a year had the ignition light come on but if i stop the van and restart it, it will go out .
mileage to date 37K. normal journey times 20 minutes and no accessories on to drain the battery, ( i wouldn't dare!)
