Refined Detail wrote:Cheers. Will chuck one in the van and try that next time. Out of interest, how easy a fix is that and what sort of cost?
Refined Detail wrote:Does sound pretty similar to mine then, never had the battery light on though.
Is on charge again tonight, yet when it's running it reads right sort of voltages etc so really confused.
Just to add, mines 2004 04 plate, with just over 30K on the clock and afaik original battery, alternator, starter motor etc etc etc
EDIT: Just seen your reply Howard - thanks. Battery terminals are fine, will check the engine earth strap - although where is it? Again AFAIK everything else is in order.
Grenadekid wrote:Personally from my experiences with our fleet of trannys in the yard i would replace the battery on them symptoms. as altransit said batterys can be misleading as i have found out in the past and most people mess around trying to find faults where there is none rather than spending the 60 or 80 quid which somebody has probably already charged you for fault finding at the van already.The first sign of cold weather or frost can really test a battery especially if its 5 years old or over
