Retrofit Trip Comp & Adjustable Intermittant - Possible ??
Postby poormansporsche » Mon Dec 21, 2009 11:50 pm
alright peeps,
2 Part Post !
Firstly, ive got a replacement speedo cluster on the way with trip computer (my old one hasnt got one) - to get it working is there anything else required other than cluster swap and indicator stalk swap - im assuming ive got the wiring as there are 2 looms going to the back of the cluster - are there any extra relays et al required or is it not compatible full stop
secondly - ive got a spare mondeo stalk sitting here with adjustable intermittant wipe which looks pretty much identical to the original connect stalk (with the adjuster obviously) - is it possible to fit and make work ? - on the mondeo it was just a case of bunging on and putting a relay in the fusebox - is this possible on the connect ????
cheers
Brett
55 LX, ST220 Leather Recaro's, Leather Dash,Console, Visors and roof lining, Vantuner Remap, Chrome Running Boards, Zetec S 18 Alloys, Zetec S Leather Wheel, Double Din Nav, Custom Dials, Blue ledded etc
poormansporsche
Re: Retrofit Trip Comp & Adjustable Intermittant - Possible ??
Postby trigger » Mon Dec 21, 2009 11:52 pm
You don't say what mark of van it's going in
Mk5 Transit the daddy
trigger
Postby psv-hgv-flt » Mon Dec 21, 2009 11:56 pm
it has been done. (its on hear someware) chris from leicster i think, 100t280 ..???
psv-hgv-flt
Postby g-man » Tue Dec 22, 2009 12:09 am
poormansporsche wrote:alright peeps,
cheers
Brett
its been tried b4,don't think it was done', but if you do tell us,could do with it
g-man
Postby poormansporsche » Tue Dec 22, 2009 11:40 pm
well ive bunged on the stalk and everything works apart from the adjustable intermittant bit - so if anyones got any ideas it would be appreciated - although I seem to remember on the ole vectra B i once had it required some form of soldering somewhere in the colomn ??
poormansporsche
Postby stephenferguson » Wed Dec 23, 2009 12:11 am
Did you put the intermittant relay in ? Think it is on here somewhere on another post, but they had to run another wire from the stalk to the relay or summit like that!!
2008, VW Transporter T5, T30, 6 Speed 130, Reflex Silver.
2006, 100 T280, MWB, Mid Roof, Moondust Silver. SOLD
Mk6-Mk7 Facelift Photos Here
stephenferguson
Postby poormansporsche » Wed Dec 23, 2009 1:01 am
havent bunged the relay in, got to find out what relay and where it goes - funnily enough I have noticed there is a wire going from one side of the stalk to the other ??
Back to the first part about the trip computer - is there supposed to be a "brain" somewhere or is it part of the ECU ????
poormansporsche
Postby stephenferguson » Wed Dec 23, 2009 5:56 pm
You will need to put the relay in like... turn them on and listen to see which relay clicks, then swap it. post your results cos its a mod am wanting to do :D
stephenferguson
