bonnet
bonnet
Postby mylo rooney » Wed Dec 30, 2009 10:58 am
been trying for a few days to get bonnet open on my 2003 model no luck with the key keep pressing down on bonnet as well but still no joy,any ideas as i need to look at water oil,etc
mylo rooney
Re: bonnet
Postby sc_BK » Wed Dec 30, 2009 3:11 pm
Is the key turning?
sc_BK
Re: bonnet
Postby mylo rooney » Wed Dec 30, 2009 4:10 pm
only a little each way,done all the pressing down on bonnet trying to flick it wd 40,but still no ,i am going to get a new key cut monday if that fails dont know what to do ,thanks
mylo rooney
Re: bonnet
Postby FATBOYFIN » Wed Dec 30, 2009 8:26 pm
press the radiator grill inwards around the key hole as you turn the key I have to do this to mine somtimes,
FATBOYFIN
Re: bonnet
Postby mylo rooney » Wed Dec 30, 2009 9:42 pm
just been trying that but no luck will try again in morning, cheers
mylo rooney
Re: bonnet
Postby mylo rooney » Thu Dec 31, 2009 12:23 pm
still cant get it open ,doing my box in now. : :evil:
mylo rooney
Re: bonnet
Postby ake » Thu Dec 31, 2009 12:38 pm
Have you opened it before with that key? Do you have a spare key you could try?
Re: bonnet
Postby winterheating » Thu Dec 31, 2009 1:27 pm
have you tried a new key yet :?:
winterheating
Re: bonnet
Postby mylo rooney » Thu Dec 31, 2009 2:43 pm
not got a spare key,i can only get a key cut on monday now,thanks for replies,but il keep trying it.
mylo rooney
Re: bonnet
Postby sc_BK » Thu Dec 31, 2009 5:34 pm
Have you tried taking off the grille? Are you sure it isn't frozen?
The key should go about 1/4 turn anti clockwise to release the bonnet about 2cm then turn it clockwise whilst lifting the bonnet
sc_BK
Re: bonnet
Postby mylo rooney » Thu Dec 31, 2009 6:15 pm
had the bonnet open lots of times,its not frozen,not had the grill off ,does it clipp off on sides,its a 2003 connect
mylo rooney
Re: bonnet
Postby mylo rooney » Sat Jan 02, 2010 10:05 pm
STILL NO BLUDDY LUCK GETTING BONNET OPEN..................
mylo rooney
Re: bonnet
Postby swishvan » Sun Jan 03, 2010 9:02 pm
turn the key upside down if its worn they work better one way than the other
swishvan
Re: bonnet
Postby winterheating » Sun Jan 03, 2010 9:33 pm
or just get a new key cut
winterheating
Re: bonnet
Postby crabeychris » Sun Jan 03, 2010 9:57 pm
I had this happend to me the other day. It ended up being that i needed a new key cut. £120 from Ford! complete rip off!
crabeychris
