TDCi upgrades?
Re: TDCi upgrades?
Postby Rumble bee » Sun Jan 31, 2010 9:31 am
Pic of my newly fitted boost gauge,
100 internet cool points to whoever posts a pic of where to plumb the bloody thing in!!!!
Chris
Rumble bee
Re: TDCi upgrades?
Postby mattvik30 » Sun Jan 31, 2010 11:20 am
Rumblebee did you fit the gauge yourself? If so how easy was the job?
Tourneo connect 90ps Remapped by Vantuner, Mondy interior handles, Full SS exhaust with pptuning de-cat, Chrome Sportvan Grille, Fiesta St Seats, Dvd Player with Kenwood speakers,
Clear Side Repeaters, K&N Air Filter, Sportvan Sideskirts
mattvik30
Re: TDCi upgrades?
Postby belly » Sun Jan 31, 2010 12:47 pm
Nice job Rumble bee 8) Very Vw Audi stylee in the vent :wink: there's a vac hose coming off the inlet manifold t into that! As for the injector's i might be able to get specs on some ie: flow rates/sizes/fitments etc as a good mate works here
http://www.pandadiesel.co.uk/
The trouble i see is the whole fuel system isn't great even if we could fit upgrade injectors how about the rail/pump/spider valve? Remember winding the boost up on the tiny turbo will also raise charge temp's Im not saying don't ive been into tuning stuff for years and well up for seeing what can be done, Unfortunately my connect is my main income! so i can't risk experimenting with it :( After exhaust/de-cat/filter i'd try a better intercooler next or even re-position the existing oe item :D
belly
Kaiser Chief
Re: TDCi upgrades?
Postby Rumble bee » Sun Jan 31, 2010 1:20 pm
Took 5 mins to fit just snipped the air vent vanes and slid it in. Simple
belly wrote:there's a vac hose coming off the inlet manifold t into that!
Thanks will have a look later.
Chris.
Rumble bee
Re: TDCi upgrades?
Postby Rumble bee » Sun Jan 31, 2010 4:48 pm
Is it this lower pipe?
Rumble bee
Re: TDCi upgrades?
Postby belly » Sun Jan 31, 2010 5:03 pm
I can't see to well in that pic! but if it's coming out of the manifold yeh t into that :D I will go and have a look at mine in a mo! i'm currently still hanging from a heavy night on the sauce :lol:
belly
Kaiser Chief
Re: TDCi upgrades?
Postby Rumble bee » Sun Jan 31, 2010 5:05 pm
Lol cheers mate, if you could post a pic that would be great :D
Rumble bee
Re: TDCi upgrades?
Postby belly » Sun Jan 31, 2010 5:07 pm
Will do :D
belly
Kaiser Chief
Re: TDCi upgrades?
Postby belly » Sun Jan 31, 2010 6:13 pm
Ive just been and had a look! No need for a photo, that hose you pointed to Rumble bee is the one! The one going up to the sensor just tee into that :wink:
belly
Kaiser Chief
Re: TDCi upgrades?
Postby Rumble bee » Sun Jan 31, 2010 6:35 pm
Cheers, the tee which came with boost gauge is just to large to fit in the pipe, and ive already cut the hose :oops:
Any idea what the sensor at the end is for?
Rumble bee
Re: TDCi upgrades?
Postby belly » Sun Jan 31, 2010 6:39 pm
I'm not to sure tbh i think its the map sensor for the ecu! basically you need it :?
belly
Kaiser Chief
Re: TDCi upgrades?
Postby Rumble bee » Sun Jan 31, 2010 6:49 pm
Fortunatley managed to piece it back together with a smaller pipe inside the vac pipe. Hopefully it will do till I can get a proper connector for it.
Rumble bee
Re: TDCi upgrades?
Postby poormansporsche » Mon Feb 01, 2010 10:50 pm
Boost Gauge Mounting Mark 2 - not going to stay there but will do for the while (behind this panel is where it came through the bulkhead)
:D
55 LX, ST220 Leather Recaro's, Leather Dash,Console, Visors and roof lining, Vantuner Remap, Chrome Running Boards, Zetec S 18 Alloys, Zetec S Leather Wheel, Double Din Nav, Custom Dials, Blue ledded etc
poormansporsche
Re: TDCi upgrades?
Postby mvirdee » Wed Mar 30, 2011 12:27 pm
Hi Please advise which is the Vacum hose- the one on the left or right???
Which Boost gauage have you fitted - its looks great :)
Thank you :)
T200 Limited 110
mvirdee
Re: TDCi upgrades?
Postby cpur » Sun Oct 08, 2017 4:56 pm
In Malta, it was normal to give these engines massive boost levels.
I had a mk3 fiesta myself which was driven daily with 2.5bar , I had no intercooler ( was always in my mind but didn't have enough money to fit one ). It was the old 1.8 diesel engine, which originally was out from ford with no turbo. I remember floor the pedal on 4th gear and it still used to spin the wheels. It surely was 150bhp and with alot of torque. However in Malta this was nothing so special, diesels where faster than petrol.
Now if we used to get that kind of power with uncalibrated diesel amounts and factory injection timing, i believe that todays TDCIs can output over 200bhp with suitable turbo and intercooler and a proper remap. It is the same block and the same internals i believe, correct me if i am wrong.
I always believe that a power full diesel engine is more economical.
I have now a 2006 connect 90, with a pressure fooling box. I have a boost gauge which shows 15psi. tried to vent the signal to the actuator but will remain at 15.
It needs a harder spring. My friend has a 2008 90bhp connect it goes slightly faster than mine. He says his diagnostic shows 20psi, Turbo is the same , but it has the siemens diesel system, and the intercooler is not tilted , it is vertical.
cheers
cpur
