poormansporsche wrote:i dont know how you read these boost gauges as its showing 18psi under full boost !!
stephenferguson wrote:the pipe is the one that comes out of the inlet manifold, its the angled one that sits under the egr valve. Not the pipe that comes out of the egr valve tho! its underneath and it goes to a black box attached to the bulkhead.
failing that just tap into the inlet manifold.
