by proximus » Mon Apr 12, 2010 10:42 am
Hi I've got an 03 1.8 TDDi and every 3rd/4th tank fill up I put in a can of STP. This has the advantage of cleaning all the injectors/ pump etc and by driving reservedly your mpg should increase. I never do above 70 and my mpg is hovering around the 40+. There again depends on what goods there are in the van and also tyre pressures and also roof fitments. If you've got stuff on the roof fit a windjammer. Hope this helps a bit.
I wanted a lighter colour but until its invented I'll stick with white!
