Hi, have the dreaded 'limp mode under load' fault on my 05 connect.
Had codes read... P0251 & P1211
Changed filters - still faulty.
Have had the EGR valve checked - valve ok.
Have had all 4 injectors changed at £799 - still have fault although performance slightly improved.
Changed rail and sensor - still faulty.
Had codes read again, garage convinced it is the Delphi fuel pump.
I have bought a recon one (12 months warranty)... is this a DIY job to change? I have friends who work on old landrovers, so not over technical but used to getting under a bonnet.
What is involved in changing a fuel pump or should I just get a garage to do it?
Cheers.
