connect fault codes
connect fault codes
Postby gizmo1122 » Mon Oct 11, 2010 1:00 pm
connect 52 reg,1.8 duro,
just scanned it again and faults are
P1246 alternator load input (see P0622) ?.
P1632 smart alt faults sensor circuit malfunction.
P1211 injection control pressure sensor.
P0251 injection pump fuel metering control A.
drive for 5 mins then heater plug light comes on and stays on,not flashing,then van dies not limp mode,can start back up straight away but same problem again after 1 minute,
i have changed fuel filter,
i have already put a brand new alternator on yesterday,what are these faults and how do i fix them,
any help please,
i have had this van for 3mths and not used it has broke down on way home,
i have about 3000 in this van now,so i am ill,i dont want to sell it on so somebody else has the problem i am not like that,but i am pretty determined not to be defeated by this one,
gizmo1122
Re: connect fault codes
Postby ddubb1 » Mon Oct 11, 2010 5:12 pm
Hi
I had same fault on mine and it turned out to be the pump, ouch!!
ddubb1
Postby gizmo1122 » Mon Oct 11, 2010 7:17 pm
diesel pump how much cost you,
heater plug light flashes not stay on has said before,
gizmo1122
