Timing Belt on Connect T200 L
Postby Srobify » Mon Nov 22, 2010 10:26 pm
Hi, Im new.
Really enjoying the topics.
I have a 2006 Transit Connect T200 L,
64,000 miles,
When should the timing belt be done?
How much is the kit and what other work should be carried out at the same time.
Cheers,
Rob.
2006 Transit Connect T200L 1.8 TDCI
Srobify
Re: Timing Belt on Connect T200 L
Postby airconman » Mon Nov 22, 2010 10:33 pm
Vehicle air conditioning services pm for details Truck specialist
airconman
Postby Srobify » Mon Nov 22, 2010 10:45 pm
eh ok
Srobify
Postby airconman » Mon Nov 22, 2010 11:17 pm
and its due at 150000 mile sorry missed it out lol
airconman
Postby Srobify » Tue Nov 23, 2010 11:20 pm
cheers
Srobify
Postby nokites » Tue Nov 23, 2010 11:30 pm
Only use cam belt kits made by Gates,used as original parts by manufactures which can be purchased from most good motor factors
OLD CHINESE PROVERB
Man who works for nothing and women who f****s for nothing ---------ALLWAYS GOT PLENTY TO DO
nokites
Postby BLUECONNECTION » Tue Nov 23, 2010 11:39 pm
nokites wrote:Only use cam belt kits made by Gates,used as original parts by manufactures which can be purchased from most good motor factors
agreed, i think my gates belt cost me £70 inc tensioner from my local motor factor, peace of mind at the end of the day, make sure you change the tensioner, its that thats more likely to let go than the belt
BLUECONNECTION
Postby nokites » Tue Nov 23, 2010 11:41 pm
Thats why i advised him to by a cam belt kit. thank you blueconnection I wish alot more owners like yourself would buy quality parts instead of the crap of ebay
OLD CHINESE PROVERB
nokites
Postby Srobify » Tue Nov 23, 2010 11:48 pm
thanks guys.
any idea what mileage I should change the belt?
Srobify
Postby BLUECONNECTION » Tue Nov 23, 2010 11:57 pm
Srobify wrote:thanks guys.
i did mine about 60k and it will get done again at 120k but thats just me, cheaper to change the belt than the engine, i don't think ford even know sometimes, some say @100k others say 150k, all a bit high if you ask me. if you don't know the history of the van or its been abused get it done now
BLUECONNECTION
Postby Srobify » Wed Nov 24, 2010 12:01 am
Ye i was thinking 150k sounds VERY high!
I am of the opinion myself that it should be changed between 60k and 70k on any car or van.
Srobify
Postby BLUECONNECTION » Wed Nov 24, 2010 12:05 am
don't even attempt it unless you have the locking kit, slopping tip-ex around will not do :(
BLUECONNECTION
Postby jwb_moto » Wed Nov 24, 2010 2:29 am
I take it this tool kit would do the job? or does anyone know which specific locking pins to get?
http://cgi.ebay.co.uk/Franklin-FORD-Con ... 2a06544d5f
I also found a genuine for belt and tensioner on ebay for £58.99 + £3.95 p&p
http://cgi.ebay.co.uk/Genuine-Ford-Fies ... 1c16dbfe45
KartGraffix Need custom vinyl Graphics give me a shout!
Get your Vatuner.com decals here
jwb_moto
Postby airconman » Wed Nov 24, 2010 2:25 pm
how hard is the tensioner and belt to change? 150k wont be too bad wil it if they say thats when to change it they wouldnt say it would they if it wasnt true. is there only one camshaft on there vans?
airconman
Postby BLUECONNECTION » Wed Nov 24, 2010 9:19 pm
jwb_moto wrote:I take it this tool kit would do the job? or does anyone know which specific locking pins to get?
yes that locking pin kit looks like it would work but I would still go to the local motor factors and get the gates belt kit
airconman wrote:how hard is the tensioner and belt to change? 150k wont be too bad wil it if they say thats when to change it they wouldnt say it would they if it wasnt true. is there only one camshaft on there vans?
its quite easy, engine mount off, rocker cover off, alternator off inc mounting bracket, starter motor off and time it up with the timing kit then undo tensioner and cam pulley, the belt only stretches between camshaft and the pump, with the removal of the cam pulley it acts like a vernier pulley when you tighten it all up. it took me about 3 hours to do as it was my first time on this engine and yes, these being only 8 valve engines they have a single cam
BLUECONNECTION
