Instrument panel illuminated when ignition off
Re: Instrument panel illuminated when ignition off
Postby Altransit » Wed Dec 29, 2010 10:55 pm
Richard001 wrote: What do you do to get the headlights to stay on after you have locked it (time extinguishd headlights)
On the Focus, you flash the headlights using the H/L flasher stalk, then get out and lock up.
They stay on for about a minute IIRC :D
Postby fordmk1mad » Sun Sep 11, 2011 3:45 pm
Old thread i know but i just bought a 2005 connect T200 and i have had this very same problem, When going out to my van at night i would notice the dash lights are on but dimly. i also have noticed a lack of power from the battery and have attributed this to the dash lights staying on. Has anyone found an answer to this problem yet or experienced the same or similar?
2003 90PS 2.4td LWB Semi High Top Minibus / Camper
fordmk1mad
Postby ake » Mon Sep 12, 2011 6:38 am
Thats the same as the MK7 Transit, which does leave the display illuminated for 5 minutes after you lock up
Postby flyingdoc » Mon Feb 18, 2013 4:48 pm
HI, had exactly the same problem on my partners 06 ford focus keyless entry system, seen loads of posts with no easy fix + loads of expense ..diagnostics not worth a light , i found the relevant fuse in handbook ...took it out and run a small 2core wire to it with a little switch out of the way that also acts as an imobiliser , not perfect ..but it cost me nowt..just one solution that stops the battery getting drained when left for a few days ...wich is a right pain in the perverbial ..hope this helps if only temporary ; )
flyingdoc
