engine mountings?
engine mountings?
Postby marcus57 » Tue Jan 04, 2011 4:36 pm
Hi all can anyone tell me how many engine mountings there are on the connect? And are they main dealer as have been told my engine mountings are nackered!! When i rev the engine up the engines moving quite a bit it makes the van judder when stationary too which cant be right? Any help would be really appreciated ta.
marcus57
Re: engine mountings?
Postby bikemadmark » Tue Jan 04, 2011 6:08 pm
cant be 100% sure about the connect, but normally 3 engine mounts are fitted to front wheel drive vehicles. I do know that the connect suffers from the rear gearbox mount failing.
These are available from a well known online auction site, just picked one up myself for about £60 delivered.
bikemadmark
Postby kjdiscos » Tue Jan 04, 2011 6:11 pm
if it is bottom gearbox mount, is more likey 30 quid delivered tbh
http://shop.ebay.co.uk/?_from=R40&_trks ... Categories
not sure why you paid 60 :x its only 58 from a stealer
kjdiscos
Postby marcus57 » Tue Jan 04, 2011 6:26 pm
Its the mountings either side of the engine its moving about quite a lot is there one either side of the engine and a gear box mouting aswell?
marcus57
Postby bikemadmark » Tue Jan 04, 2011 6:32 pm
kjdiscos wrote:if it is bottom gearbox mount, is more likey 30 quid delivered tbh
Just checked my ebay account, £24 plus £5 delivery.
bikemadmark
Postby kjdiscos » Tue Jan 04, 2011 6:37 pm
the top engine mounts are pricey :O, Theres one near the expansion tank you will see it, and another at from i think cant remember of top head, but there pricey :O
kjdiscos
Postby marcus57 » Tue Jan 04, 2011 6:54 pm
Yeah apparently my mechanic said its two that need doing i could see the one on the left... is there another one then a gear box mounting? He said u can only get them from a main dealer but i called transit parts and they do a front engine mounting for 59 inc would that be the two at the front? I just reslly need to save some money its the wrong side of xmas to be paying out and buying them from a main dealer is going to cost a packett??? I had the clutch and slave done last year by a differant mechanic and he said that he had allot of grief doing it as one of the bolts on the mountings had been sheard off that would be the gear box mounting then? I just really could do eithout this at the moment i know nothing about engines lol
marcus57
Postby kjdiscos » Tue Jan 04, 2011 7:02 pm
Which mount is it that transit parts refer to ? is it genuine ford or oem ?
im sure blue connection will be along tonite he will know for sure :D what mounts you need.
Im same as you marcus know f all about engines ha, i have a good mechanic mate that fixes mine like.
kjdiscos
Postby marcus57 » Tue Jan 04, 2011 7:18 pm
They said it was a front engine mounting?? When i called europarts they said they only did the off side one? So im really confused!!! I think there ford parts the clutch ans slave i got where last year! The mechanics round here in east london are slippery at the best of times but this time of the year even more so just want to try and save some money mate you know!!
marcus57
Postby Kent Discos » Tue Jan 04, 2011 7:58 pm
Jack Wilson | Transit Connect - 1.8, T220, 75PS |
18" ST alloys, JBL Sound System, LED Lights, Colour Coded, Toad A850, 8000K HIDs, Stainless Dials, Map by Vantuner, Air Horn, Recaros, Lowered
Kent Discos - http://www.kentdiscos.me.uk
Kent Discos
Postby marcus57 » Tue Jan 04, 2011 8:47 pm
Yeah it judders when stationary!! That sounds right to me so there about 30 each and the other about 60 the mechanic said 80 to do it so thats not the end of the world i suppose thanks for your help mate really appreciated ta M
marcus57
Postby Kent Discos » Tue Jan 04, 2011 9:34 pm
i had a word with ford dealers today, went to get the alternator loom and asked about gear box mounting (lower) and he quoted me £26+VAT so - £31 ish :wink:
need to get mine done, my misfire doesn't help the shaking :lol:
Kent Discos
Postby marcus57 » Wed Jan 05, 2011 7:05 pm
Cheers mate for the help took the van in earlier to another mechanic i use and he said that its the gear box mounting that needs doing so getting it done tomorrow he said it was 51 plus vat for the part that seems a bit dear will pull him about it ta mate
marcus57
Postby Simon46 » Tue Jul 03, 2012 2:54 pm
Did it fix the shuddering? Which ones were replaced? Mine is doing it in neutral around 1300 rpm. Rear has been replaced.
Regards simon.
05 90PS Transit connect Silver.
Simon46
Postby Kent Discos » Tue Jul 03, 2012 8:32 pm
Simon46 wrote:Did it fix the shuddering? Which ones were replaced? Mine is doing it in neutral around 1300 rpm. Rear has been replaced.
Regards simon.
my lower rear mount fixed some of my knock and shudder
Kent Discos
