Alternator Voltage question - answered!
Re: Alternator Voltage question - answered!
Postby GasEngineer » Wed Feb 13, 2013 5:26 pm
GasEngineer wrote:Great forum - I have just joined and already fixed my battery light! I just cut the damaged sections of the wires (about 50mm) and spliced together with some heat shrink crimp connectors.
As with Mrspot, I am puzzled about step 7 though -there is the plug on the alternator but the wire then just heads up to the fuse box behind the battery. I can't see any plug at the top end.
Also I took the intercooler off as advised, but there was no cover as mentioned in steps 4 & 5 - the plug is just accessible there on the alternator. I had a new starter motor a year ago and I'm wondering if something may have been removed when this was changed and not replaced?
Well it's been a year and no one has taken the trouble to reply. Maybe not such a great forum after all !! :wink:
GasEngineer
Postby Altransit » Wed Feb 13, 2013 7:04 pm
Maybe because no one knows what you have or don't have, on your van :roll: Most of us are just owners like yourself, not fully paid Ford technicians.
I notice that you haven't imparted any help to anyone in the year that you've been here either :?
Postby miki.l5pnt » Mon Mar 25, 2013 1:47 pm
hi ,
had the problem found breaks in wireing, problem solved , came back new alternator problem solved , and again porblem , my question is , are you able to check the alternaor voltage from the smartcharge plug at all to find if working correctley ?
many thnaks
miki
miki.l5pnt
Postby Karl88van » Thu Jul 07, 2016 10:56 am
my battery with engine running is showing 13.57 and 12.00 with engine off.
Can a faulty loom cause a lesser reading when engine running or is my alternator on its way out ?
Battery light been on 3 weeks.
Visually checked wires from alternator and look ok.
Regards
Karl88van
Postby walt1984 » Thu Jul 07, 2016 11:15 am
That sounds low with engine running.
If light is on its not charging correctly.
The cheap fix is to replace the short piece of loom that connects into main loom behind the rad and plugs into alternator.
Sent from my P330X using Tapatalk
"due to ever increasing work load the light at the end of the tunnel has been turned off!"
walt1984
Postby Karl88van » Thu Jul 07, 2016 11:45 am
That loom in pick doesnt look very old on my van and i cant find any breaks in it but shud it be faulty that wouldnt cause my low reading when running should it ?
Karl88van
Postby Karl88van » Thu Jul 07, 2016 4:10 pm
Anyone got an old 1 of these lying around? I could do with the plug that connects to alternator with enough wire still attached so i can join, just removed my and inspected it and that end apears to have melted slightly.
Karl88van
Postby Kenton » Fri Nov 03, 2017 10:48 am
I thought i had this problem just before the end of last winter. Battery light on, and battery draining fast, just got to the garage with little time left as the ABS light, airbag light, & ECU light had all come on, headlights like candles. So first was to look at the loom. Took it off, and inspected. Some patches had the beginnings of wear, so we repaired. Checked all the connections were fine, also checked resistance in the loom. All good! Checked output again, and... nothing. So changed alternator (stupid expensive!! For a van!!) And all has been good since. Definitely worth checking front loom first still.
2005 T230 LX 90 TDCi LWB
ST 17" alloys
Focus ST170 seats
Fiesta Zetec S/W & G/K
Mondeo Inner Door handles & vents
Sport spoiler
Blacked h/lights
Side bars
Facelift rear lights
Lined/carpeted
Lowered on Gaz kit
110 intercooler
De-Cat
Remapped
Kenton
Postby DevonMike » Mon Sep 19, 2022 6:48 pm
With regards to the smart charge system, when I got my connect I noticed my alternator was charging the battery constantly over 15 volts, soo ive merely disconnected the 3 pin plug from the alternator and it now charges (with a little rev when starting) at 14.2 volts
eventually I will replace the regulator...
DevonMike
