Fitting The ipod Lead
Re: Fitting The ipod Lead
Postby Paulyu1983 » Sun Mar 31, 2013 3:52 pm
Have just bought one of these connects2 iPhone kits for my 6000 CD player
http://www.connects2.co.uk/ProductInfor ... x?id=11730
Just wondering if anyone has fitted one before and if I will still be able to use the controls on the steering wheel.
Paulyu1983
Postby Maccyski » Tue Jul 02, 2013 7:26 pm
Brilliant Idea!!
Was just about to drill a hole on the top of the dash!!
Maccyski
Postby Gaffa » Wed Jul 31, 2013 12:31 am
Looking at doing this on mine this week going to buy the parts in a moment, did you get the fitting for the blank part with it and what did you do for it to fit there like that.
Gaffa
Postby Gaffa » Mon Aug 05, 2013 6:03 pm
Anyone ?
Gaffa
Postby alix76 » Fri Aug 08, 2014 4:05 pm
Is it not easise to buy a bt stereo
alix76
Postby 1967spud » Sun Nov 16, 2014 3:58 pm
Paulyu1983 wrote:Have just bought one of these connects2 iPhone kits for my 6000 CD player
how have you found it now you have had it a while?
1967spud
Postby alix76 » Sun Jan 04, 2015 1:42 pm
Why not go for a Bluetooth system
alix76
Postby Rednalman » Tue Apr 21, 2015 7:52 pm
http://www.ebay.co.uk/itm/360898166479? ... EBIDX%3AIT
I bought this off eBay. It came with the tools to remove the unit. I dropped the lead down the side and under the centre console. It comes out by the handbrake. You just plug it into your phone/iPod and press 'AUX' on the CD player. It works great and only took about 5 mins to fit.
Rednalman
Postby m16uel » Wed Nov 18, 2015 8:07 pm
Hi does anyone know where i can get another blanking plate as my pal drilled the whole a bit to big he thought he was drilling 20mm but instead it was 25mm
m16uel
Postby jonochap » Wed Nov 18, 2015 8:10 pm
Having never made such an obvious mistake I've found that a vast selection of rubber grommets works well until one turns up
jonochap
Postby m16uel » Mon Nov 23, 2015 8:58 pm
jonochap wrote:Having never made such an obvious mistake I've found that a vast selection of rubber grommets works well until one turns up
i managed to get another blanking cover and I've drilled a 20mm hole this time I'm still having difficulty it clipping on or am i missing something??
m16uel
Postby brotheroak » Tue Dec 29, 2015 6:19 pm
m16uel wrote:i managed to get another blanking cover and I've drilled a 20mm hole this time I'm still having difficulty it clipping on or am i missing something??
Could you tell me where you got one of those? I managed to snap off the fixing tabs on one of my blanking plates and need to get a replacement. Cheers.
brotheroak
