Jamz_ wrote:Right this van is starting to do my head in. Sorted other issues out (battery light) and put a new induction hose on as it ha a hole in.
Anyway, town driving in the van is fine and short fast trips are no bother. But when the father in law goes to the whole sales on the motorway (10-15miles?) the coil light comes on and flashes and then cuts the van power off completely. But as soon as he restarts the van no light and drives fine again.
I've read on here things from injectors, egr valve, throttle pedal. Any ideas?
Mylee wrote:Try some millers injector cleaner. Won't cure the problem, but certainly made mine better.
Jamz_ wrote:Mylee wrote:Try some millers injector cleaner. Won't cure the problem, but certainly made mine better.
Was thinking about using some redex or something similar... will give it a try
EvilT wrote:Same fault when driving, but consistent 30% fuel overpressure after new filter even at idle on the pluggittin. Software says P1211 (pump pressure), and P0251 (fuel metering control). Could it just be crappy diesel fouling the system?Mylee wrote:Try some millers injector cleaner. Won't cure the problem, but certainly made mine better.
what happened afterward?
