Graham Taylor wrote:Woolf
I used this stuffhttp://www.ebay.co.uk/itm/like/28135865 ... 0&ff14=108
Basically thoroughly clean the surface with detergent and a scotch pad then apply a thin coat and just build it up from there, about three coats should give a good coverage. I then gave it a thin coat of spray dye from Halfords just to get an even finish
Cheers mate,might give that a go
