paul2012 wrote:
Do a search on here - you will find several members on here that have tried fitting a full EGR blank on Euro 4 engines & they have thrown on MIL light
One when a small hole will be ok
NOTE:- If there's a problem with EGR valves on Euro 4 engines a blanking plate will not fix it
Cal1990 wrote:Finally got the bolts out the egr to put blanking plate in! All is well so far seems to pull far better from bottom end to top with no flat spots
Happy as larry!!
mushnafen wrote:Cal1990 wrote:Finally got the bolts out the egr to put blanking plate in! All is well so far seems to pull far better from bottom end to top with no flat spots
Happy as larry!!
Good Work Fella, did your blanking plate have the hole in the middle or was it a solid one?
